Use Cases
Contact Center
— Contact Center
Build a contact center where humans and AI work together.
Define the routing and queues once, then let AI and human agents share the same calls, passing context back and forth as they go.
SW-UseCase-ContactCenter
The hard part
Contact Center complexity lives in the telephony layer.
Traditional platforms hand you conference bridges, task queues, and webhooks. The state management, transfer logic, and queue handling that turn them into a contact center are yours to build from scratch.
So you rebuild call state from webhooks that arrive late, out of order, or not at all, always a step behind the live calls. The caller feels it on every transfer: the call moves but the context doesn't.
How it works
The telephony layer, up close
Follow one caller through a contact center running on SignalWire. Every piece is a platform primitive, and the human and AI agents are addressed the same way.
01
Agents are platform identities
Human and AI agents are registered as identities on the platform, each with its own address and presence.
02
Routing runs on live state
Routing runs in code on the call's real-time state, not a copy rebuilt from webhook events that arrive late or out of order.
03
Queues run native
Queueing is native to the platform, and because the call carries its own state, a caller keeps their identity and history through the wait.
04
Transfers carry the whole call
A transfer carries the call's full identity and context, whether it goes from a human to an AI or an AI to a human.
05
Live calls stay addressable
A live call stays addressable, so a human or an AI can drop in mid-call to monitor, whisper to the agent, or join outright.
01
02
03
Queues run native
04
05
01
02
03
Queues run native
04
05
Build it
Route your first call to a human or AI agent.
You define routing, queues, and agents as SWML, in a file or generated from code, and the platform runs it. Human and AI agents are both destinations, addressed the same way.
yaml
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - answer: {}
    - request:
        url: 'https://api.example.com/lookup'
        method: POST
        body:
        save_variables: true
    - switch:
        variable: request_response.tier
        case:
          priority:
            - connect:
                to: 'queue:priority'
          support:
            - ai:
                prompt:
                  text: You are a support agent. Help the caller with their account.
                SWAIG:
                  functions:
                    - function: get_account
                      description: Look up the caller's account details
                      parameters:
                        type: object
                        properties:
                          account_id:
                            type: string
                            description: The caller's account number
        default:
          - connect:
              to: 'queue:general'
yaml
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - answer: {}
    - request:
        method: POST
        body:
    - switch:
        case:
          priority:
            - connect:
          support:
            - ai:
                prompt:
                SWAIG:
                  functions:
                      parameters:
                        type: object
                        properties:
                          account_id:
                            type: string
        default:
          - connect:
              to: 'queue:general'
yaml
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - answer: {}
    - request:
        method: POST
        body:
    - switch:
        case:
          priority:
            - connect:
          support:
            - ai:
                prompt:
                SWAIG:
                  functions:
                      parameters:
                        type: object
                        properties:
                          account_id:
                            type: string
        default:
          - connect:
              to: 'queue:general'
yaml
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - answer: {}
    - request:
        method: POST
        body:
    - switch:
        case:
          priority:
            - connect:
          support:
            - ai:
                prompt:
                SWAIG:
                  functions:
                      parameters:
                        type: object
                        properties:
                          account_id:
                            type: string
        default:
          - connect:
              to: 'queue:general'
What you'll have after the quickstart
Routing that runs on the call's live state
Native queues that hold each caller's context
Transfers that carry the whole call, to a human or an AI
One event stream showing every routing decision and handoff
The platform behind it
The SignalWire tools behind Contact Centers
Build it the way you already work: as config, in your language's SDK, or over plain HTTP. These are the tools behind your contact center.
SWML
Declarative markup for routing, queues, transfers, and AI agents. Write it directly, or generate it from code.
Server SDKs
Build routing and AI agents in Python or nine other languages. The SDK generates SWML for you.
REST APIs
Provision numbers, manage resources, and control active calls over HTTP.
Browser SDK
Put agents or customers on a call from a web, mobile, or desktop app.
RELAY
A persistent WebSocket for real-time call control. Monitor, whisper, or join a live call from your own code.
The building blocks you route to: agent identities, AI agents, queues, and conferences, all addressable the same way.
SWML
Server SDKs
REST APIs
Browser SDK
RELAY
SWML
Server SDKs
REST APIs
Browser SDK
RELAY
The hard parts
The hard parts and how SignalWire handles them
The Challenge
How SignalWire Handles It
You assemble the contact center from conference bridges, queues, and routing, then maintain the state machine that ties them together.
Routing, queueing, and transfers are native. The state that ties them together lives on the call, not in your application.
Transfers drop context. The caller re-verifies and repeats everything to the next agent.
The call is stateful, so a transfer carries identity, authentication, and history, to a human or an AI.
Adding AI means bolting a second stack onto your telephony and gluing them with webhooks.
AI agents are first-class. You add them as destinations you already route to, no second stack.
It works in the demo, then buckles at real call volume.
The same carrier-grade engine has run telephony at scale for twenty years.
The Challenge
In production
Built by teams that answer at scale.
“We were able to accomplish what our customers needed a lot more quickly with SignalWire AI than with other standalone call flow systems.”
Avatar
Justin Massey
Founder and CEO at RelayHawk
Avatar
Justin Massey
FAQ
Everything you might want to know about AI in the contact center.
Why do contact centers need a control plane instead of a CPaaS?
Traditional CPaaS platforms treat interactions as transactions: fire a webhook, receive an event, manage state yourself. This breaks when AI is involved, since agents need context from earlier in the call and need to coordinate handoffs without losing the thread. A control plane keeps all of this inside the platform, so your systems observe and instruct it instead of reconstructing it.
How do AI agents work in a SignalWire contact center?
SignalWire's AI kernel runs inside the media engine, in the same system that carries the call; the control plane is the programmable surface (SWML) you govern it through. Calls are handled under constraints defined in SignalWire Markup Language (SWML): which tools the AI can invoke, what data it can see, when to escalate. If it needs customer data or a workflow trigger, it calls a SWAIG function; your backend returns what happens next while the platform coordinates the millisecond-level media operations.
How does SignalWire handle context when a call transfers from an AI agent to a human?
Call state lives in SignalWire's control plane rather than in the AI agent or your application, so context carries over automatically. When a caller moves from AI to a human agent, the full interaction history, collected data, and routing context travel with the call, because the call never leaves the platform.
What protocols does SignalWire support for contact center infrastructure?
The control plane is protocol-agnostic.  PSTN, SIP trunks, WebRTC browser clients, and messaging channels all route to the same resources under the same logic. One AI agent can handle phone, web, and messaging without separate code paths, and transfers between protocols preserve context.
Can I integrate SignalWire with Salesforce, HubSpot, or Zendesk?
Yes. SignalWire connects to CRMs and business systems via SWAIG functions. When an agent or call flow needs customer data, it calls a function that queries your CRM and returns the result. Any system with an API can be integrated this way.
Ready to ship advanced contact center functionality?
Sign up and start building. Every SignalWire Space includes free credit to test end to end.
