This article presents Holy Guacamole, an extensible, production-grade reference application showing how to build a reliable voice-AI drive-thru system with SignalWire’s Python Agents SDK, emphasizing backend-controlled state management, real-time menu matching, and deterministic logic instead of prompt-only approaches. It covers core architectural patterns like state machines, business rule enforcement, TF-IDF and alias matching for menus, SWAIG functions for structured operations, and real-time UI updates using Call Fabric and WebRTC.
Live demo: https://holyguacamole.signalwire.me
Source code: GitHub repo
How to build better drive-thru voice AI
Fast food drive-thrus are a tough problem for AI systems. You’re dealing with ambient noise, unpredictable phrasing, and complex menu logic. Yet most implementations rely on simple prompt engineering and think that will be good enough.
Holy Guacamole is SignalWire’s example of how to do drive-thru AI correctly. It’s a developer-first reference application built with SignalWire’s Python Agents SDK. The entire interaction is driven by your application logic, not the LLM. That means deterministic behavior, production-grade control, and a significantly better customer experience.
This demo acts as a blueprint for building scalable, voice-first systems using SignalWire’s Call Fabric architecture the correct way, carrying context, managing state, implementing proper guardrails, and planning ahead for business logic failures.
Core features
Voice-first interaction using SignalWire's Agents SDK
Real-time frontend order display via WebRTC
Intelligent menu matching with TF-IDF, aliases, and fallback algorithms
Automatic combo detection handled entirely in code
Production-grade protections like rate limiting, max value enforcement, and error handling
The backend handles all state transitions, menu matching, and business logic. The AI agent is simply an interface for natural language understanding and response generation, tightly controlled by application logic.
Code-powered AI prompting
Instead of relying on LLMs to remember instructions, the Holy Guacamole model demonstrates a more effective method of prompting: enforcing rules through structured functions.
Traditional approach (unreliable)
prompt = """You are a drive-thru assistant..."""
This relies on the LLM to behave correctly, remember constraints, and apply logic on its own.
Code-driven approach (reliable)
def add_item(args, raw_data):
if quantity > MAX_ITEMS_PER_TYPE:
quantity = MAX_ITEMS_PER_TYPE
combo_suggestion = check_combo_opportunity(items)
subtotal = sum(item["total"] for item in items)
response = f"Added {quantity} {item_data['name']}"
if combo_suggestion:
response += f"\n\n{combo_suggestion}"
result = SwaigFunctionResult(response)
result.swml_user_event({
"type": "item_added",
"items": items
return resultclient = Client("...", "..."
signalwire_space_url="your
-space.signalwire.com")
# reference a live call by SID and redirect it mid-flight
call = client.calls("call-sid").update(
url="https://example.com/new-handler")
"items": items
"items": items
"items": items
This guarantees predictable outcomes regardless of LLM behavior.
Project setup
The application is written in Python and built on the SignalWire Agents SDK.
git clone https:
cd sigmond-holyguacamole
python -m venv venv
source venv/bin/activate
pip install -r requirements.txt
git clone https:
python -m venv venv
git clone https:
python -m venv venv
git clone https:
python -m venv venv
Start the application locally:
Instructions for deploying with Dokku or other production environments are in the repository.
State machine overview
Example: Greeting state
The conversation flows through structured states:
def _configure_states(self):
contexts = self.define_contexts()
default_context = contexts.add_context("default") \
.add_section("Goal", "Take accurate food orders efficiently")
default_context.add_step("greeting") \
.add_section("Current Task", "Welcome the customer and start their order") \
.add_bullets("Process", [
"Welcome them warmly to Holy Guacamole!",
"Ask what they'd like to order"
.set_functions(["add_item"]) \
.set_valid_steps(["taking_order"])
default_context.add_step("taking_order") \
.set_functions([
"add_item", "remove_item", "modify_quantity",
"review_order", "finalize_order", "upgrade_to_combo"
.set_valid_steps(["confirming_order"])
.set_functions([
.set_functions([
.set_functions([
Each state includes:
Allowed function calls
Next valid transitions
Defined goals and business rules
Transitions are controlled by the backend, never left to the LLM.
SWAIG functions: Structured interactions
SWAIG functions define all operations the AI agent can invoke. Each is explicitly defined, typed, and safely handled.
Example: add_item
@self.tool(
name="add_item",
description="Add an item to the order",
parameters={
"type": "object",
"properties": {
"item_name": {
"type": "string",
"description": "The menu item to add"
"quantity": {
"type": "integer",
"description": "Number of items to add",
"default": 1
"required": ["item_name"]
order_state, global_data = get_order_state(raw_data)
item_name = args["item_name"]
quantity = args.get("quantity", 1)
MAX_ITEMS_PER_TYPE = 20
MAX_TOTAL_ITEMS = 50
if quantity > 10:
quantity = 10
sku, item_data, category = find_menu_item(item_name)
if not sku:
return SwaigFunctionResult(f"I couldn't find '{item_name}' on our menu")
existing_item = next((item for item in order_state["items"]
if item["sku"] == sku), None)
if existing_item:
existing_item["quantity"] += quantity
existing_item["total"] = existing_item["quantity"] * existing_item["price"]
else:
order_state["items"].append({
"sku": sku,
"name": item_data["name"],
"quantity": quantity,
"price": item_data["price"],
"total": quantity * item_data["price"]
order_state["subtotal"] = sum(item["total"] for item in order_state["items"])
order_state["tax"] = round(order_state["subtotal"] * 0.10, 2)
order_state["total"] = order_state["subtotal"] + order_state["tax"]
order_state["item_count"] = sum(item["quantity"] for item in order_state["items"])
combo_suggestion = check_combo_opportunity(order_state["items"])
response = f"I've added {quantity} {item_data['name']}"
response += f" for ${quantity * item_data['price']:.2f}."
response += f" Your total is now ${order_state['total']:.2f}."
save_order_state(result, order_state, global_data)
"items": order_state["items"],
"subtotal": order_state["subtotal"],
"tax": order_state["tax"],
"total": order_state["total"]
if global_data.get("current_step") == "greeting":
result.context = "taking_order"
return result
@self.tool(
name="add_item",
parameters={
"type": "object",
"properties": {
"item_name": {
"type": "string",
"quantity": {
"type": "integer",
"default": 1
if quantity > 10:
quantity = 10
if not sku:
if existing_item:
else:
"sku": sku,
return result
@self.tool(
name="add_item",
parameters={
"type": "object",
"properties": {
"item_name": {
"type": "string",
"quantity": {
"type": "integer",
"default": 1
if quantity > 10:
quantity = 10
if not sku:
if existing_item:
else:
"sku": sku,
return result
@self.tool(
name="add_item",
parameters={
"type": "object",
"properties": {
"item_name": {
"type": "string",
"quantity": {
"type": "integer",
"default": 1
if quantity > 10:
quantity = 10
if not sku:
if existing_item:
else:
"sku": sku,
return result
These functions handle validation, pricing, real-time UI updates, and business logic, all outside the LLM’s control.
Menu matching logic
The backend uses a multi-algorithm approach to interpret what users want:
TF-IDF vector similarity for fast matching
Alias mapping for exact matches
Fallback string matching when others fail
def find_menu_item(item_name):
"""Multi-algorithm menu matching"""
item_lower = item_name.lower().strip()
if HAS_SKLEARN and self.vectorizer:
user_vector = self.vectorizer.transform([item_lower])
similarities = cosine_similarity(user_vector, self.menu_vectors)[0]
best_idx = np.argmax(similarities)
best_score = similarities[best_idx]
if best_score > 0.3:
sku, item_data, category = self.sku_map[best_idx]
return sku, item_data, category
for sku, aliases in MENU_ALIASES.items():
if item_lower in [alias.lower() for alias in aliases]:
for category, items in MENU.items():
if sku in items:
return sku, items[sku], category
if sku in items:
if sku in items:
if sku in items:
The combination allows the system to handle natural phrasing without sacrificing accuracy.
Combo detection
No AI prompt is needed to upsell a combo. Instead, detection happens entirely in code:
def check_combo_opportunity(items):
"""Automatic combo detection without LLM awareness"""
if not items:
return None
taco_count = sum(item["quantity"] for item in items
if "taco" in item["name"].lower())
burrito_count = sum(item["quantity"] for item in items
if "burrito" in item["name"].lower())
chips_count = sum(item["quantity"] for item in items
if "chips" in item["name"].lower()
and "salsa" in item["name"].lower())
drink_count = sum(item["quantity"] for item in items
if "small" in item["name"].lower()
and "drink" in item["name"].lower())
if taco_count >= 2 and chips_count >= 1 and drink_count >= 1:
taco_price = 3.49 * 2
chips_price = 2.99
drink_price = 1.99
current_total = taco_price + chips_price + drink_price
combo_price = 9.99
savings = round(current_total - combo_price, 2)
return (f"💡 Great news! I can upgrade your 2 tacos, chips & salsa, "
f"and drink to a Taco Combo and save you ${savings:.2f}!")
return None def check_combo_opportunity(items):
if not items:
return None
chips_price = 2.99
drink_price = 1.99
combo_price = 9.99
if not items:
return None
chips_price = 2.99
drink_price = 1.99
combo_price = 9.99
if not items:
return None
chips_price = 2.99
drink_price = 1.99
combo_price = 9.99
return None
The function returns a suggestion that the LLM simply relays. No reasoning or memory required.
Real-time event handling frontend integration
The frontend uses SignalWire Call Fabric Browser SDK for media and user event delivery over WebRTC. Events are handled in JavaScript:
function handleUserEvent(event) {
const { type, items, subtotal, tax, total } = event.detail;
switch(type) {
case 'item_added':
case 'item_removed':
updateOrderDisplay(items);
updateTotals(subtotal, tax, total);
break;
case 'combo_upgraded':
showComboAnimation();
break;
case 'order_complete':
showOrderNumber(event.detail.order_number);
break;
switch(type) {
case 'item_added':
break;
break;
break;
switch(type) {
case 'item_added':
break;
break;
break;
switch(type) {
case 'item_added':
break;
break;
break;
This ensures low-latency UI updates and a smooth ordering experience.
Advanced features
Order protection: Limits on total quantity, item types, and maximum order value
Natural language totals: Converts prices to spoken words (e.g., “thirteen dollars and fifty cents”)
Multi-item parsing: Handles complex inputs like “two tacos and three burritos”
Error recovery: Offers suggestions or categories if an item isn’t found
Reusable state machine structure
Real-time visual feedback via swml_user_event()
Real-time UI updates via events
Event flow:
Customer → AI Agent → Backend Logic → swml_user_event() → Frontend Event Handler → UI Update
Consistent event types like item_added, combo_upgraded, order_completed, etc., ensure frontend sync.
Start building a production-ready, customer-facing voice AI agent
Holy Guacamole is a blueprint for building real-time, voice-controlled AI experiences that are actually maintainable in production. It demonstrates how to:
Control the LLM with code
Enforce business logic outside the model
Use SignalWire’s Programmable Unified Communications platform to power intelligent audio apps
Scale deterministic AI logic that works across edge cases
This is production-ready architecture for anyone serious about voice automation.
Ready to build your own? Sign up for a free account, and bring your questions to our community of developers on Discord.
