SIP Trunking
Businesses often want to place outbound calls from phone numbers their customers already recognize. In some cases, that means keeping an existing number with another provider. In others, it means fully moving that number into a new platform.
SignalWire supports both paths:
Verified Caller ID, which lets you use an existing number for outbound calls without porting it
Local Number Portability (LNP), which transfers full ownership of a number into SignalWire
Understanding the difference helps you choose the right option for your calling workflow.
What is verified caller ID?
Verified caller ID allows you to use a phone number you already own as the outbound caller ID for calls placed through SignalWire.
Instead of porting the number, you verify ownership by completing a short verification process. Once verified, SignalWire allows that number to be used as the “From” value on outbound voice calls.
This option is useful when:
You already have a number with another carrier
You only need the number for outbound calling
You do not want to move inbound service or messaging
Verified Caller ID is outbound-only and does not transfer the number’s service.
How verified caller ID works
The verification process confirms that you control the phone number:
You submit the phone number in the SignalWire dashboard
SignalWire places an automated call to that number
You enter the verification code provided during the call
The number becomes eligible for outbound caller ID use
Once verified, the number can be used for outbound calls from SignalWire without changing its existing carrier or service.
What is local number portability (LNP)?
Local Number Portability allows you to fully move an existing phone number from another carrier into SignalWire.
When a number is ported:
SignalWire becomes the service provider for that number
The number can be used for inbound calls
The number can be used for outbound calls
Messaging services can be enabled
Call routing and automation can be applied
Porting is the right choice when you want full control over how a number behaves.
Verified caller ID vs porting a number
While both options let you call from a familiar number, they serve different purposes.
Verified Caller ID:
Outbound calls only
No inbound calling
No messaging
Faster setup
Number remains with the original carrier
Ported number:
Inbound and outbound calling
Messaging support
Full routing and automation
Complete platform control
Number service fully moves to SignalWire
Choosing between them depends on whether you need full telecom functionality or just outbound caller identification.
When to use verified caller ID
Verified caller ID is best suited for:
Outbound sales or support calls
Temporary campaigns
Gradual platform migrations
Situations where inbound calls remain with another provider
It allows teams to start calling immediately without waiting for a porting process.
When to port a phone number
Porting is recommended when:
You want inbound calls handled by SignalWire
You need SMS or MMS on the same number
You want programmable routing, IVR, or automation
You are consolidating telecom infrastructure
Ported numbers behave like native SignalWire numbers.
Compliance and trust considerations
Using verified or ported numbers helps:
Maintain consistent caller identity
Reduce call blocking from carriers
Improve answer rates by using recognizable numbers
Align with caller ID authentication frameworks
SignalWire enforces verification and ownership checks to prevent spoofing and misuse.
Getting started
You can:
Verify an existing number for outbound calling in the SignalWire dashboard
Initiate a port request to bring a number fully into SignalWire
Both options are designed to support legitimate business calling while preserving flexibility.
Then, bring any questions to our community on Discord.
What is Verified Caller ID?
Verified Caller ID lets you use an existing phone number you already own as the caller ID for outbound calls through SignalWire by proving ownership via a verification process.
How do I verify my existing phone number with SignalWire?
In your SignalWire Dashboard, go to Phone Numbers → Verified, click Verify a Phone Number, enter the number, and complete the verification code you receive via a call to that number.
What is Local Number Portability (LNP)?
Local Number Portability lets you keep your existing phone number when moving to a new telecom provider or platform, such as bringing it into SignalWire, without changing the number.
What’s the difference between Verified Caller ID and porting a number?
Verified Caller ID allows outbound caller ID without moving the number’s service, while porting fully transfers the number into SignalWire so it can be used with all SignalWire services such as incoming calls, SMS, and full outbound use.
Why would I want to port my phone number instead of just verifying it?
Porting gives you access to the full suite of SignalWire services for that number, including inbound traffic and messaging, while Verified Caller ID only covers outbound caller ID without moving the service.
