Text to Speech (TTS) lets your voice application speak dynamic prompts to callers without pre-recorded audio, which is useful for customer service greetings, announcements, and menu experiences that need to change frequently. This guide shows how to play TTS with the SignalWire RELAY Realtime SDK using the playTTS method, including choosing synthesized voices and languages, and using Speech Synthesis Markup Language (SSML) for finer control over pronunciation, cadence, and emphasis.
Text-to-Speech with SignalWire Server SDKs
Programmable voice technology allows you to expand your customer service operations: greeting guests, providing routine assistance, or directing callers to relevant agents and associates. Synthesized voice, also known as text-to-speech (TTS), empowers businesses with scalable support systems that can reach diverse audiences at any time of day.
We recently discussed text-to-speech using our compatibility API, but with SignalWire, there is more than one method to implement this tool. In this post, we’ll go over how to use TTS with our Browser SDK using the play method. If you’d prefer a video format, you can watch that below.
Server SDKs for Voice
Drafting a programmable voice application in Node.js that makes and receives voice calls–to and from both traditional PSTN numbers and SIP endpoints–is quick and easy when using the RELAY Realtime SDK. Our RELAY APIs use WebSocket technology, which allow for simultaneous and bi-directional data transmission. Using the RELAY Realtime SDK, you too can deploy low latency voice applications, featuring text-to-speech, using a simple script.
Reading a message
For the purposes of this blog, we’ll focus specifically on the play method. The play method enables you to play text-to-speech to the caller.
copy
01
02
03
04
05
06
07
08
09
import{Voice}from"@signalwire/realtime-api";constclient = newVoice.Client({project:"<project-id>",token:"<api-token>",contexts:["SiS"],});client.on("call.received",async(call)=>{console.log("Call received:",call.id,call.from,call.to);try{awaitcall.answer();console.log("Inbound call answered");constplayback = awaitcall.playTTS({text:"Welcome to SignalWire!"});awaitplayback.ended();console.log("Text to Speech ended");}catch(error){console.error("Error answering inbound call",error);}call.hangup();console.log("Call disconnected");});
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
A diversity of languages
SignalWire can tap into the synthesized voices provided by Amazon Polly and Google Cloud to intuitively customize the gender and language of your text-to-speech. Here, you can augment your synthesized voice to address an audience that speaks European Portuguese.
copy
01
02
03
04
05
06
07
08
09
import{Voice}from"@signalwire/realtime-api";constclient = newVoice.Client({project:"<project-id>",token:"<api-token>",contexts:["SiS"],});client.on("call.received",async(call)=>{console.log("Call received:",call.id,call.from,call.to);try{awaitcall.answer();console.log("Inbound call answered");constplayback = awaitcall.playTTS({language:"pt-PT",voice:"Polly.Ines-Neural",text:"Boa tarde, hoje está um dia tão bonito!"});awaitplayback.ended();console.log("Text to Speech ended");}catch(error){console.error("Error answering inbound call",error);}call.hangup();console.log("Call disconnected");});
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Speech synthesis markup language (SSML)
SignalWire’s Browser SDKs can also employ the Speech Synthesis Markup Language for more granular control over how our synthesized voice is presented to the caller.
By wrapping your text in the <speak> tag, you can make use of subsequent SSML tags to alter the cadence and pronunciation, among other parameters, of your text-to-speech. See Amazon Polly or Google Cloud documentation for supported tags.
copy
01
02
03
04
05
06
07
08
09
import{Voice}from"@signalwire/realtime-api";constclient = newVoice.Client({project:"<project-id>",token:"<api-token>",contexts:["SiS"],});client.on("call.received",async(call)=>{console.log("Call received:",call.id,call.from,call.to);try{awaitcall.answer();console.log("Inbound call answered");constplayback = awaitcall.playTTS({language:"en-GB",voice:"Polly.Brian-Neural",text:`<speak>
Here are a few <say-as interpret-as="characters">SSML</say-as> samples.
I can pause <break time="1s"/> in the midst of a sentence.
<prosody rate="x-fast">I can speak exceptionally quickly.</prosody>
<prosody rate="x-slow">Or I can slow my cadence to a crawl.</prosody>
I can speak in cardinals: Your number is <say-as interpret-as="cardinal">13</say-as>.
And I can speak in ordinals: You are <say-as interpret-as="ordinal">13</say-as> in line.
I can even pronounce digits: The digits for thirteen are
<say-as interpret-as="characters">13</say-as>.
<p>Which leads me to wonder...</p>
<p>What will <say-as interpret-as="characters">TTS</say-as>
and SignalWire's awesome software-defined telecom inspire YOU to develop?</p>
</speak>`});awaitplayback.ended();console.log("Text to Speech ended");}catch(error){console.error("Error answering inbound call",error);}call.hangup();console.log("Call disconnected");});
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
What will SignalWire’s inspire you to develop? If you have any questions while getting started with our programmable Voice API, stop by our Community Discord to connect with our team.
What is Text to Speech (TTS)?
Text to Speech (TTS) converts text into spoken audio during a live call, so your application can generate prompts dynamically instead of relying only on prerecorded files.
How do you play Text to Speech (TTS) using the SignalWire Server SDKs?
Use the play method to speak a text string to the caller, which lets you generate and play prompts on demand inside your call handling logic.
How do you change the language or voice for Text to Speech (TTS)?
SignalWire can use synthesized voices from providers like Amazon Polly and Google Cloud, allowing you to select voices and languages that fit your audience.
What is Speech Synthesis Markup Language (SSML), and when should you use it?
Speech Synthesis Markup Language (SSML) is markup you add around TTS text, such as a <speak> wrapper and additional tags, to control delivery details like cadence and pronunciation.
