10 min
SWAIG 101: Your Complete Guide to Voice AI Function Integration
Master SignalWire's AI Gateway with the Agents SDK - from basics to production deployment
Jon Gray Headshot
Jon Gray
Solutions Architect
Developer Tutorials
SignalWire AI Gateway (SWAIG) lets voice AI agents call backend functions in real time, bending external API calls and business logic directly into live voice conversations without brittle webhook chains. This guide explains how SWAIG works with the Agents SDK, from the @SWAIGFunction decorator and DataMaps to rich request contexts and advanced patterns, so developers can integrate external services into voice AI systems with minimal complexity.
This guide will walk through the basics of creating an AI Culinary Companion by integrating Spoonacular with a voice AI agent. Follow along in the Recipe AI Agent Github Repo
What is SWAIG?
SignalWire AI Gateway (SWAIG) allows voice AI agents to delegate tasks to your backend via HTTP POST. Think of it like CGI (Common Gateway Interface) - where a web server hands off execution to an external program using raw query strings or form-encoded data - but for AI agents.
Traditional AI function integration often looks like the Model Context Protocol (MCP): multiple services stitched together, lots of orchestration, and brittle webhook chains. It works, but it’s imperative and heavy.
The key difference? SWAIG allows you to incorporate external API calls into your AI agent conversation in real time - seamlessly, during natural voice conversations, without awkward pauses or "please hold" moments.
Why SWAIG + Agents SDK Changes Everything
Traditional voice AI architecture requires multiple services, webhook management, and complex orchestration. The SignalWire Agents SDK eliminates this complexity: the agent SDK allows you to set up these functions, set up a web server, and build complex AI agents (with POM), ALL IN A SINGLE PYTHON FILE!
Here's your complete voice AI system:
copy
01
02
03
04
05
06
07
08
09
from signalwire_agents import AgentBase, SWAIGFunction, DataMap
class MyVoiceAI(AgentBase):
        super().__init__(name="My Agent", port=5000, use_pom=True)
    @SWAIGFunction(name="my_function", description="Does something useful")
    def my_function(self, parameter: str):
        return {"result": "success"}
    MyVoiceAI().run()  # Complete production voice AI server
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
SWAIG 101: Understanding the Basics
Step 1: The @SWAIGFunction Decorator
The @SWAIGFunction decorator is your gateway to real-time API integration. Here's how our recipe agent example demonstrates the pattern:
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="search_recipes",
               description="Find recipes based on ingredients, cuisine type, or dietary restrictions")
def search_recipes(self, query: str, ingredients: str = None,
                  cuisine: str = None, max_results: int = 3):
    """SWAIG function that integrates with external APIs"""
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Key Elements:
  • name: How the AI identifies the function
  • description: Tells the AI when to use this function
  • Parameters: Automatically parsed from voice input
  • Type hints: Enable automatic validation
Step 2: DataMaps for Declarative API Integration
The DataMap system handles API calls declaratively. Instead of imperative code with error handling, you describe what you want:
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="search_recipes")
def search_recipes(self, query: str, max_results: int = 3):
    # Using the excellent Spoonacular Food API (shoutout to their comprehensive recipe database!)
    data_map = DataMap(
        url="https://api.spoonacular.com/recipes/complexSearch",
        method="GET",
        input={
            "query": "${query}",
            "number": "${max_results}",
            "apiKey": "${SPOONACULAR_API_KEY}",
            "addRecipeInformation": "true"
        output={
            "recipe_count": "${results.length}",
            "recipes": "${results[*].{id: id, title: title, readyInMinutes: readyInMinutes}}"
    return self.swaig_data_map(data_map, query=query, max_results=max_results)
copy
01
02
03
04
05
06
07
08
09
    data_map = DataMap(
        method="GET",
        input={
        output={
copy
01
02
03
04
05
06
07
08
09
    data_map = DataMap(
        method="GET",
        input={
        output={
copy
01
02
03
04
05
06
07
08
09
    data_map = DataMap(
        method="GET",
        input={
        output={
DataMap handles automatically:
  • HTTP request formatting
  • Parameter substitution (${variable} syntax)
  • JSON response parsing
  • Error handling and retries
  • Response transformation
Step 3: Understanding SWAIG Request Context
SWAIG requests include rich context: The function name (e.g., "search_movie"), Parsed arguments in the structured argument.parsed field, The full argument schema (argument_desc) to describe expected inputs, Session, caller, and project context so you can make smart decisions without additional lookups
This rich context enables powerful patterns like automatic authentication using caller ID.
Advanced SWAIG Patterns
Custom Logic with SwaigFunctionResult
For complex business logic beyond simple API calls, use custom SWAIG functions with the SwaigFunctionResult class:
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="create_meal_plan",
               description="Generate a personalized meal plan")
def create_meal_plan(self, days: int, dietary_restrictions: list = None):
    """Complex multi-step logic in a SWAIG function"""
    # Multi-step business logic
    user_profile = self._get_user_dietary_profile()
    available_ingredients = self._check_pantry_inventory()
    seasonal_adjustments = self._calculate_seasonal_preferences()
    # Generate comprehensive meal plan
    meal_plan = MealPlanGenerator(
        profile=user_profile,
        constraints={
            'restrictions': dietary_restrictions,
            'inventory': available_ingredients
    ).generate(days)
    return SwaigFunctionResult(
        response=f"I've created a {days}-day meal plan tailored to your preferences...",
        action_data={"meal_plan_id": meal_plan.id}
copy
01
02
03
04
05
06
07
08
09
        constraints={
    ).generate(days)
copy
01
02
03
04
05
06
07
08
09
        constraints={
    ).generate(days)
copy
01
02
03
04
05
06
07
08
09
        constraints={
    ).generate(days)
SwaigFunctionResult enables:
  • Natural language responses for the AI to speak
  • Action data for conversation state management
  • Complex response orchestration
Error Handling and Graceful Degradation
Production SWAIG functions handle failures elegantly:
copy
01
02
03
04
05
06
07
08
09
def search_recipes(self, query: str, **kwargs):
    try:
        return self.swaig_data_map(data_map, **kwargs)
    except APITimeoutError:
        # Fallback to cached data
        fallback_recipes = self._get_cached_popular_recipes()
            response="The recipe service is running slow, but I have some popular suggestions...",
            action_data={"fallback_used": True, "recipes": fallback_recipes}
    except APIError:
            response="I'm having trouble with the recipe database. Would you like me to suggest some classic dishes I know well?"
copy
01
02
03
04
05
06
07
08
09
    try:
    except APIError:
copy
01
02
03
04
05
06
07
08
09
    try:
    except APIError:
copy
01
02
03
04
05
06
07
08
09
    try:
    except APIError:
State Management Across Conversations
SWAIG functions can persist data across phone calls using the built-in state management:
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="save_recipe_rating")
def save_recipe_rating(self, recipe_id: str, rating: int, notes: str = ""):
    """Persistent user preferences"""
    user_prefs = self.state_manager.get_state(self.session_id, "preferences", {})
    user_prefs.setdefault("recipe_history", []).append({
        "recipe_id": recipe_id,
        "rating": rating,
        "timestamp": datetime.now().isoformat()
    self.state_manager.set_state(self.session_id, "preferences", user_prefs)
        response=f"Thanks! I'll remember you rated this {rating}/5 stars."
copy
01
02
03
04
05
06
07
08
09
        "rating": rating,
copy
01
02
03
04
05
06
07
08
09
        "rating": rating,
copy
01
02
03
04
05
06
07
08
09
        "rating": rating,
Universal SWAIG Patterns
The beauty of SWAIG? This pattern works with ANY API. Swap out Spoonacular for:
  • E-commerce: Product searches and inventory checks
  • Travel: Flight prices and hotel availability
  • Finance: Stock quotes and account balances
  • Healthcare: Appointment scheduling and prescription refills
  • Real Estate: Property listings and market data
  • Customer Service: Account lookups and order status (using caller ID for automatic authentication)
Need authenticated APIs? SWAIG handles that too. The rich context includes caller information, so you can automatically authenticate users and access their personal data without asking them to recite account numbers over the phone.
Integrating with the Agents SDK
Setting Up Your Agent Foundation
The AgentBase class provides the foundation for creating AI-powered agents using the SignalWire AI Agent SDK. It extends the SignalWire Markup Language (SWML) Service class, inheriting all its SWML document creation and serving capabilities, while adding AI-specific functionality
copy
01
02
03
04
05
06
07
08
09
class RecipeAgent(AgentBase):
        super().__init__(
            name="Chef Assistant",
            host="0.0.0.0",
            port=5000,
            use_pom=True,  # Enable Prompt Object Model
            record_call=True,  # Built-in call recording
            auto_answer=True   # Automatic call handling
        self._setup_agent_personality()
        self._setup_conversation_contexts()
copy
01
02
03
04
05
06
07
08
09
        super().__init__(
            host="0.0.0.0",
            port=5000,
copy
01
02
03
04
05
06
07
08
09
        super().__init__(
            host="0.0.0.0",
            port=5000,
copy
01
02
03
04
05
06
07
08
09
        super().__init__(
            host="0.0.0.0",
            port=5000,
Configuring AI Behavior with POM
The Prompt Object Model (POM) structures AI behavior configuration:
copy
01
02
03
04
05
06
07
08
09
def _setup_agent_personality(self):
    """Configure AI behavior declaratively"""
    self.prompt_add_section("Role",
        "You are a master chef with 20 years of experience, "
        "passionate about teaching cooking and helping people "
        "create delicious meals at home."
    self.prompt_add_section("Guidelines", [
        "Always ask about dietary restrictions first",
        "Provide encouraging feedback during cooking",
        "Offer ingredient substitutions when needed"
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Context-Aware Function Availability
Define which SWAIG functions are available in different conversation contexts:
copy
01
02
03
04
05
06
07
08
09
def _setup_conversation_contexts(self):
    """Define specialized conversation contexts"""
    # Recipe Discovery Context
    self.prompt_add_context("recipe_search", [
        "search_recipes", "get_recipe_details", "suggest_alternatives"
    # Active Cooking Context
    self.prompt_add_context("cooking_guidance", [
        "get_next_step", "set_timer", "handle_cooking_questions"
    # Meal Planning Context
    self.prompt_add_context("meal_planning", [
        "create_meal_plan", "save_recipe_rating", "get_shopping_list"
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
SWAIG Best Practices
1. Function Design Principles
  • Single responsibility: Each SWAIG function should do one thing well
  • Clear descriptions: Help the AI understand when to call your function
  • Sensible defaults: Use optional parameters with reasonable defaults
  • Error handling: Always handle API failures gracefully
2. DataMap Optimization
copy
01
02
03
04
05
06
07
08
09
# Good: Specific, focused data extraction
output={
    "recipes": "${results[*].{id: id, title: title, cookTime: readyInMinutes}}"
# Avoid: Returning entire API responses
output={"raw_response": "${*}"}  # Too much unused data
copy
01
02
03
04
05
06
07
08
09
output={
copy
01
02
03
04
05
06
07
08
09
output={
copy
01
02
03
04
05
06
07
08
09
output={
3. State Management Strategy
  • Use session state for conversation-specific data
  • Use global state for shared/cached data
  • Implement state cleanup for expired data
  • Consider state size limits for performance
4. Voice-Optimized Responses
copy
01
02
03
04
05
06
07
08
09
    # Good: Conversational, scannable for voice
    response="I found 3 great pasta recipes: **Creamy Mushroom Fettuccine** (25 mins), **Pasta Primavera** (20 mins), and **Carbonara** (15 mins). Which sounds good?",
    # Avoid: Dense text blocks hard to speak naturally
    response="Recipe search results: 1. Creamy Mushroom Fettuccine - Prep time 25 minutes, Difficulty intermediate..."
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Production Deployment Guide
Environment Configuration
Set up your environment variables:
copy
01
02
03
04
05
06
07
08
09
export SPOONACULAR_API_KEY="your_api_key_here"
export SIGNALWIRE_PROJECT_ID="your_project_id"
export SIGNALWIRE_TOKEN="your_token"
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Single File Deployment
The AgentBase class automatically handles deployment environments:
copy
01
02
03
04
05
06
07
08
09
    RecipeAgent().run()  # Works in all environments
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Automatic environment detection:
  • Local development: Starts web server
  • AWS Lambda: Configures as Lambda handler
  • Docker: Handles containerization
  • Cloud Functions: Adapts automatically
Testing Your SWAIG Functions
Test individual functions during development:
copy
01
02
03
04
05
06
07
08
09
# Test SWAIG function directly
agent = RecipeAgent()
result = agent.search_recipes("pasta", ingredients="mushrooms", max_results=3)
print(result)
copy
01
02
03
04
05
06
07
08
09
print(result)
copy
01
02
03
04
05
06
07
08
09
print(result)
copy
01
02
03
04
05
06
07
08
09
print(result)
Common SWAIG Patterns and Examples
Pattern 1: Simple API Integration
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="get_weather", description="Get current weather")
def get_weather(self, location: str):
    weather_map = DataMap(
        url="https://api.openweathermap.org/data/2.5/weather",
        input={"q": "${location}", "appid": "${WEATHER_API_KEY}"},
        output={"temp": "${main.temp}", "description": "${weather[0].description}"}
    return self.swaig_data_map(weather_map, location=location)
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Pattern 2: Multi-Step Business Logic
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="process_order")
def process_order(self, product: str, quantity: int):
    # Check inventory
    if not self._check_inventory(product, quantity):
        return SwaigFunctionResult(response="Sorry, insufficient inventory")
    # Calculate pricing
    price = self._calculate_price(product, quantity)
    # Reserve inventory
    reservation = self._reserve_items(product, quantity)
        response=f"Reserved {quantity} {product} for ${price}. Proceed with order?",
        action_data={"reservation_id": reservation.id}
copy
01
02
03
04
05
06
07
08
09
    # Check inventory
    # Calculate pricing
    # Reserve inventory
copy
01
02
03
04
05
06
07
08
09
    # Check inventory
    # Calculate pricing
    # Reserve inventory
copy
01
02
03
04
05
06
07
08
09
    # Check inventory
    # Calculate pricing
    # Reserve inventory
Pattern 3: Authenticated User Data
copy
01
02
03
04
05
06
07
08
09
@SWAIGFunction(name="get_account_balance")
def get_account_balance(self):
    # Use caller ID for automatic authentication
    caller_id = self.session_id  # Contains caller information
    user = self._authenticate_user(caller_id)
    balance_map = DataMap(
        url="https://banking-api.com/accounts/balance",
        headers={"Authorization": f"Bearer {user.token}"},
        input={"account_id": "${account_id}"},
        output={"balance": "${current_balance}", "available": "${available_balance}"}
    return self.swaig_data_map(balance_map, account_id=user.account_id)
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Troubleshooting Common Issues
DataMap Parameter Problems
copy
01
02
03
04
05
06
07
08
09
# Wrong: Hardcoded values
input={"query": "pasta"}
# Right: Use variable substitution
input={"query": "${query}"}
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Missing Error Handling
copy
01
02
03
04
05
06
07
08
09
# Add try/catch around API calls
try:
except Exception as e:
    return SwaigFunctionResult(response="Sorry, I'm having technical difficulties.")
copy
01
02
03
04
05
06
07
08
09
try:
copy
01
02
03
04
05
06
07
08
09
try:
copy
01
02
03
04
05
06
07
08
09
try:
State Management Issues
copy
01
02
03
04
05
06
07
08
09
# Always provide defaults for state retrieval
user_prefs = self.state_manager.get_state(self.session_id, "preferences", {})  # ✅
user_prefs = self.state_manager.get_state(self.session_id, "preferences")      # ❌ May return None
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
copy
01
02
03
04
05
06
07
08
09
Next Steps: Building Your SWAIG Application
1. Start with the Recipe Agent
Clone and explore the complete recipe agent implementation to understand all SWAIG patterns in context.
2. Study the Documentation
3. Explore More Examples
4. Build Your First Agent
Follow these steps to get your SWAIG agent running:
Step 1: Set Up Your Python Environment
pip install signalwire-agents
git clone https://github.com/signalwire/signalwire-agents.git
cd signalwire-agents
Step 2: Get Your API Keysfrom the SignalWire Dashboard
  • Get your SignalWire credentials
  • Set environment variables:
export SPOONACULAR_API_KEY="your_spoonacular_key"
Step 3: Run Your Agent Server
python recipe_agent.py  # Starts server on port 5000
Step 4: Expose Your Local Server. Install ngrok and expose your local server to the internet:
ngrok http 5000
ngrok http 5000
ngrok http 5000
ngrok http 5000
Copy the public URL (e.g., https://983f-93-41-16-193.ngro...)
Step 5: Configure Your Phone Number
  • Buy a phone number in SignalWire Dashboard
  • Create a new Resource → Script → SWML type
  • Set to "External URL" and input your ngrok URL
  • Test by calling your number!
Detailed setup instructions: Handle incoming calls from code
Welcome to SWAIG development—where enterprise voice AI becomes as simple as writing Python functions, and your biggest architectural decision is choosing meaningful function names.
Ready to dive deeper? The recipe agent demonstrates every pattern covered in this guide. Use it as your foundation for building sophisticated voice AI applications with SWAIG and the SignalWire Agents SDK.
What is SignalWire AI Gateway (SWAIG)?
SignalWire AI Gateway (SWAIG) is a system that enables AI voice agents to integrate real-time external API calls into voice conversations, avoiding complex webhook orchestration.
How does the @SWAIGFunction decorator work?
The @SWAIGFunction decorator tells the AI how to identify a function, describes when to use it, and lets the agent call it with structured parameters.
What are DataMaps in SWAIG?
DataMaps let developers describe API requests declaratively, handling parameter substitution, HTTP formatting, response parsing, and error handling automatically.
What context does a SWAIG request include?
A SWAIG request includes the function name, parsed arguments, full argument schema, session info, caller data, and project context, enabling smart decisions without extra lookups.
What are some advanced SWAIG patterns?
Advanced patterns include custom logic via SwaigFunctionResult, graceful error handling, session-wide state management, and authenticated API access, all usable in production voice AI.
